It would be great if the file list view in TSX could have some filter mechanism implemented. I believe such a feature exists for Royal TS but Royal TSX lacks this same feature.
Perhaps the textbox/entryfield could be a little bit wider?
Can we have a popup-window to do some advanced filtering, like regex for example and some options like ignore case or anything like you would like to have in advanced filtering?
Thanks again for the great responses and quick delivery of this option!
Ok, thanks. Would be cool to have a popup window where I can set some search characteristics can be set, such as “Search/filter is regexp” or “Allow wildcards” and “Search/filter is case insensitive” and so on.
Perhaps on some backlog of options to consider for future releases?
In the meantime, I can finally filter the list so I’m happy!
