Filter in FTP File view
It would be handy if the popup in the file-panel or a CTRL-F keystroke would give an option to filter files, so that you can easily find files / limit the view to that filter.
You kind kind of filter in FTP File View, but it’s not as simple as just hitting CTRL-F. To filter right-click on the column you want to filter and then click “Filter Editor…”
Thanks for the feedback! I have implemented the functionality in the next major version (V6).
I would like to add to this that I would also want to filter the files list and I see no option in Royal TSX to do so. If this gets implemented then please also include Royal TSX to have this as well.
Sccreenshot of the files list I am referring to:
on Windows there’s already a “filter panel” which can be shown with CTRL + F. I kindly ask you to create a new feature request in the Royal TSX ideas forum to better track this suggestion/feature request.
Hi Stefan
Created a similar topic in the Royal TSX Ideas forum:
Hi Steven,
as posted in your thread on the Royal TSX forum, file transfer connections will have a filter box in the next upcoming update.
best regards,
Thanks Christoph!
Looking forward to this new version!
