In Dynamic Folders with Powershell, the script is transformed to replace RoyalTS variables of the type $xxxx$ (example: $EffectiveUsername$).
In my code, if I put one of these lines :
$MyFilePath = Get-Content -Path “${RootPath}${Environment}_server_list.csv”
$MyFilePath = Get-Content -Path “${RootPath}$($Item.Environment)_server_list.csv”
I get the warning “At least one token couldn’t be resolved” in the RoyalTS logs.
The 2 lines of code are valid and working Powershell code.
I have the impression that you’re replacing variables with a regexpr of the form $\w$, i.e. all characters except space character work. In fact, the following line doesn’t generate the warning:
$MyFilePath = Get-Content -Path “${RootPath} ${Environment}_server_list.csv”
due to the space.
Among all the variables provided by RoyalTS, only the following characters seem to be used: a-z A-Z 0-9 . - :
Is it possible to update the variable replacement mechanism so that it doesn’t try to replace if there is one of these characters: ( ) { } between the 2 $ ? To have the same behavior as if it were a space character?
