PowerShell Script to create a Royal TS Document based on a CSV File
This is a sample PowerShell script that demonstrates how to create Royal TS/X documents based on the content of a CSV file.
Remark: You need to import the Royal TS PowerShell module to get this running (assuming you have installed Royal TS to the default location):
Install-Module -Name RoyalDocument.PowerShell -Scope CurrentUser
Import-Module -Name RoyalDocument.PowerShell
function CreateRoyalFolderHierarchy()
  param(
    [string]$folderStructure,
    [string]$splitter,
    $Folder
  $currentFolder = $Folder
  $folderStructure -split $splitter | %{
    $folder = $_
    $existingFolder = Get-RoyalObject -Folder $currentFolder -Name $folder -Type RoyalFolder
    if($existingFolder)
      Write-Verbose "Folder $folder already exists - using it"
      $currentFolder = $existingFolder
    else
      Write-Verbose "Folder $folder does not exist - creating it"
      $newFolder= New-RoyalObject -Folder $currentFolder -Name $folder -Type RoyalFolder
      $currentFolder  = $newFolder
  return $currentFolder
$fileName = "outputcsv.rtsz" #relative to the current file-system directory
#if(Test-Path $fileName) {Remove-Item $fileName}
$store = New-RoyalStore -UserName "PowerShellUser"
$doc = New-RoyalDocument -Store $store -Name "Powershell import from CSV" -FileName $fileName
Import-CSV -Path servers.csv | %{
  $server = $_
  Write-Host "Importing $($server.Name)"
  $lastFolder = CreateRoyalFolderHierarchy -folderStructure $server.Folder -Splitter  "\/" -Folder $doc
  $newConnection = New-RoyalObject -Folder $lastFolder -Type RoyalRDSConnection -Name $server.Name
  $newConnection.URI = $server.URI
Out-RoyalDocument -Document $doc -FileName $fileName
The above script processes a CSV file with the following structure:
Folder,Name,URI
lab/dmz,server1,127.0.0.1
lab/int,server2,127.0.0.2
lab/int,server3,127.0.0.3
