HTTP Login with Basic Auth
Hello @all,
like in this Post:
I’d like to use (must) use HTTP Basic Auth to login into a website. This seems to work with IE but not with Chrome. In the post above, there is a link to a knowledgebase site, but the basic auth entry (and config in RoyalTS) doesnt exists anymore.
Am I blind? Am I missing something?
How i can use HTTP Basic Auth with the Chrome Plugin?
(My actual RoyalTS Version is V6.1.60329)
Greetings
Marco
Hi Marco,
you just define a credential and make sure “Automatic Logon” is checked. The web browser will then try to use basic auth.
This works… :slight_smile: Many thanks for the fast response… :slight_smile:
Greetings
Marco
Glad I could help.
