We would like to be able to export the sessions of a computer/server into a CSV.
If this is not a possibility, please consider adding this as a feature.
Hi Chris,
Royal TS does actually come with a CSV Export function:
However, when exporting CSV files, only the “Common Properties” are exported by default:
You can perform connection type-specific exports by selecting RDP connections, for instance, and also selecting “Remote Desktop Connection” in the actual export dialog:
Alternatively, you can also create a PowerShell script to export the content of your documents.
The following link may be helpful:
Further information on the PowerShell module can be found here:
https://www.royalapps.com/go/kb-ts-win-powershellmodule-samples
can you try the following:
Focus the list (select one entry)
Use CTRL+A to select all entries
Use CTRL+C to copy selection to the clipboard
Paste data into notepad, excel, etc.
