based on discussion with Christoph
Mühlberger I’m submitting a feature request. Currently when trying to define web page in RoyalTS for a connection with Secure GW a message about need of defining the Secure GW as a proxy is shown and I’m not allowed to save this configuration. Unfortunately, I don’t want to use the Secure GW as a proxy but just as a tunnel. Could you add this function?
Furthermore, there is a case when I need not only to tunnel a connection to a web server but to a HTTP proxy. In this case I need to open a tunnel to a proxy and have the local port added to browser settings dynamically. This is a second function I’d like you to add.
Martin
Hi Martin,
Your first request seems a bit odd and I’m not sure I understand it correctly:
Do you want to use the host and port of the provided web page URL as the target for the tunnel, like this:
Configure a secure gateway object
Configure the web page connection to use that secure gateway object
Use the web page URL’s host and port as the target for the tunnel
Navigate to localhost:[dynamic-port]
I think I understand the second request. To clarify, this is what you are looking for:
Use the proxy host and port as the target for the tunnel
Dynamically set the proxy configuration of the web page connection to use the localhost:[dynamic-port]
Is this correct?
