I’m trying to create a Dynamic Folder Script for all members of my team.
In a shared Document, I can use $EffectiveUsername$ for example.
In a Dynamic Folder Script, when I write $EffectiveUsername$, when I’m reload, the value is empty.
is it normal ?
I have the impression that all the variables are replaced by nothing
Royal TS v6.1.60731
Best Regards,
Yann
Hi Yann,
replacement tokens in dynamic folder scripts are replaced when executing the script based on the settings of the dynamic folder. This way you can securely inject authentication information to the script without putting the clear text password(s) into the script.
Since you are running a script which dynamically populates all properties, you can simply fill in the correct credential information (or use a dynamic credential).
I hope this clears things up. Should you have any further questions, let me know.
No
This is my connections :
"Objects": [
"Type": "TerminalConnection",
"TerminalConnectionType": "SSH",
"Name": "[username] - PostGre - host (ssh)",
"ComputerName": "$EffectiveUsername$@$CustomField1$''$CustomField2$''[email protected]@gateway",
"CredentialID": "000001",
"Properties": {
"KeepAliveInterval": "60",
"SOKeepAliveOption": "true",
"PuttyLogFileFlushFrequently": "true",
"PuttyLogging": "1",
"RecordCreateSubDir": "true",
"RecorderOutputPath": "C://Local//Logs",
"RecordStartOnConnect": "true",
"CustomField1FromParent": true,
"CustomField2FromParent": true,
"CustomField3FromParent": true
In a standard Folder, all variables in the field ComputerName was replaced by their values.
In a Dynamic Folder, all varaibles are empty.
However, the values are well initialized, I can see them through the different panels.
Best Regards,
Yann
I guess I don’t understand the use case. Since you are creating these dynamic (volatile) objects using the dynamic folder script, why not just set the computer name as it should be for each object? What do you gain by using replacement tokens?
The Dynamic Folder will be shared between my team members.
1st : Each member have a personnal account ($EffectiveUsername$)
2nd : It’s more easy to modify a json file and replace any value than a modifcation in standard objects when you must update many objects.
Best Regards,
Yann
We use CyberArk and not RoyalServer TS
So, the computerName must be : vaultuser@targetuser#domainaddress@targetmachine#targetport@targetpassword@proxyaddress
If I understand your requirement correctly, you can use $EffectiveUsername$ (and password) in the script/json but you need to make sure you configure the credential on the dynamic folder and also make sure you specify credential from parent on each connection/level. Can you try that and see if it resolves the issue?
