I am trying out the new V7 Beta, and have noticed that the Navigation pane has a lot of extra spacing between the icons and text in the tree which has the effect making the tree a lot wider than V6.
Hi Christoph,
I am using the Default Colors preset, that already has the Compact mode enabled, so the screen shot from V7 that I provided is using the compact mode.
Regards
Richard
Hi Richard,
this is Stefan, the lead dev for Royal TS for Windows. With V7 we switched the theme for the UI framework we are using to a more modern Windows 10/11 like theme provided by the 3rd party vendor. While it offers a couple of tweaks (like mentioned by Christoph), it does render the UI with a bit more whitespace. Unfortunately, we can’t really change this behavior for this theme/skin. I thought it was possible but providing the “old” skin in addition to the new one is also not feasible/maintainable. The differences are too big. I’m sorry to be the bearer of bad news.
Thanks for the update and for checking.
Richard
Is it possible to provide any kind of more compact skin? RoyalTS 7 beta has so much useless whitespace even in compact mode…
The last couple of beta releases should have a more condensed view in Compact Mode, similar to what we had before. Can you check if you are running the latest version?
I’m on 7.0.20327, which AFAIK is the latest. Its density is about 15% lower than v6 (v7 in compact mode shows 38 rows in the Navigation pane, v6 shows 45 rows; honestly, I wouldn’t mind even higher density – Windows 11 Explorer shows 48 rows in the same amount of space).
Thanks for the hint. Didn’t realize there was a compact mode for the File Explorer as well.
I tried to further tweak the tree node rendering in Royal TS but I failed to compress it more without messing up other stuff in our rendering. The tree node rendering is quite complicated in our case. I’m not sure I’m able to get this done without completely rewriting the rendering logic - which is a massive task. I’m sorry I have no better news at the moment.
Thanks for the adjustments on the compact mode. I would still like to see some space saved, especially in the vertical area. The hight of the title bar could be reduced in comparison to the title bar of V6.
I’d love to be able to move the whole File, Home, Edit, Template… menu bar into the title bar to save even more space. Is this even possible with the new UI framework?
As far as I can see there’s no way to adjust the height or put the ribbon tabs into the title bar. I think the only way to get as much space vertically as possible is to invoke the Auto-Hide ribbon mode using the button left next to the minimize button.
Hi Stefan and RoyalTS team,
I can 100% agree with Richard or another users, who use Navigation instead Tabs (cause wide monitor).
I personally use RoyalTS from version1 and can tell you, that RoyalTS is my main app with outlook, and is wonderful.
I fight only with this one visual thing, and we will be happy, if we can change=reduce “spacing” in navigation tree. I believe, that you will find way, cause you are best!
Hi Lukas,
I guess you are referring to the indentation in deeper levels. Right now, we can’t really decrease the indentation as the tree control we are using doesn’t allow that. We might be able to improve this at some point in the future though.
