V5 Beta - ngen.cmd errors for file not found
I ran the ngen.cmd file as directed from the downloads page and I have attached a log file of errors from the ngen log from (C:\Windows\Microsoft.NET\Framework\v4.0.30319). I have replicated it on a VM as well and get the same errors. It looks like there are some files missing.
Hope this helps. Not sure if it is ignorable errors or not but just thought I would bring it to your attention.
09/12/2018 08:27:58.129 [2260]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe install C:\Program Files (x86)\Royal TS V5\RoyalTS.exe
09/12/2018 08:28:06.317 [2260]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.Printing.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:28:06.504 [2260]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.RichEdit.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:28:07.145 [2260]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.XtraRichEdit.v18.1, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:28:07.379 [2260]: Failed to load dependency DevExpress.Utils.v18.1.UI of assembly DevExpress.XtraCharts.v18.1.Wizard, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:28:08.411 [2260]: All compilation targets are up to date.
09/12/2018 08:28:08.427 [2260]: ngen returning 0x00000000
09/12/2018 08:31:12.007 [8416]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe uninstall C:\Program Files (x86)\Royal TS V5\RoyalTS.exe
09/12/2018 08:31:12.180 [8416]: Uninstalling assembly C:\Program Files (x86)\Royal TS V5\RoyalTS.exe
09/12/2018 08:31:18.575 [8416]: ngen returning 0x00000000
09/12/2018 08:31:18.654 [4904]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe update /queue
09/12/2018 08:31:18.762 [4904]: ngen returning 0x00000000
09/12/2018 08:33:22.786 [7132]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe install C:\Program Files (x86)\Royal TS V5\RoyalTS.exe
09/12/2018 08:33:25.974 [7132]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.Printing.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:33:26.145 [7132]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.RichEdit.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:33:26.739 [7132]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.XtraRichEdit.v18.1, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:33:26.989 [7132]: Failed to load dependency DevExpress.Utils.v18.1.UI of assembly DevExpress.XtraCharts.v18.1.Wizard, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:33:28.349 [7132]: 2>    Compiling assembly FastColoredTextBox, Version=2.16.21.0, Culture=neutral, PublicKeyToken=fb8aa12b994ef61b (CLR v4.0.30319) ...
09/12/2018 08:33:28.396 [7132]: 1>    Compiling assembly C:\Program Files (x86)\Royal TS V5\RoyalTS.exe (CLR v4.0.30319) ...
09/12/2018 08:33:30.973 [7132]: 2>    Compiling assembly System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 (CLR v4.0.30319) ...
09/12/2018 08:33:43.957 [7132]: 2>Common Language Runtime detected an invalid program. while compiling method UnsafeNativeMethods.GetAppContainerSid
09/12/2018 08:33:55.539 [7132]: 2>    Compiling assembly System.Net.Http, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:56.352 [7132]: 2>    Compiling assembly System.Runtime, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:56.977 [7132]: 2>    Compiling assembly System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 (CLR v4.0.30319) ...
09/12/2018 08:33:58.821 [7132]: 2>    Compiling assembly System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.289 [7132]: 2>    Compiling assembly System.Diagnostics.Debug, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.492 [7132]: 2>    Compiling assembly System.Security.Cryptography.X509Certificates, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.539 [7132]: 1>    Compiling assembly System.Runtime.Handles, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.680 [7132]: 2>    Compiling assembly System.Diagnostics.Tracing, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.742 [7132]: 1>    Compiling assembly System.Net.Primitives, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.883 [7132]: 2>    Compiling assembly System.Collections, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.899 [7132]: 1>    Compiling assembly System.Threading.Tasks, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:33:59.992 [7132]: 2>    Compiling assembly System.IO, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:00.117 [7132]: 2>    Compiling assembly System.Text.Encoding, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:00.258 [7132]: 2>    Compiling assembly System.Diagnostics.DiagnosticSource, Version=4.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 (CLR v4.0.30319) ...
09/12/2018 08:34:00.384 [7132]: 1>    Compiling assembly System.Reflection, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.024 [7132]: 2>    Compiling assembly System.Threading, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.134 [7132]: 1>    Compiling assembly Microsoft.Win32.Primitives, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.289 [7132]: 2>    Compiling assembly System.Runtime.InteropServices, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.352 [7132]: 1>    Compiling assembly System.Globalization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.446 [7132]: 2>    Compiling assembly System.Runtime.Extensions, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:01.524 [7132]: 1>    Compiling assembly System.IO.Compression, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 (CLR v4.0.30319) ...
09/12/2018 08:34:01.743 [7132]: 2>    Compiling assembly System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (CLR v4.0.30319) ...
09/12/2018 08:34:01.837 [7132]: 1>    Compiling assembly ActiproSoftware.SyntaxEditor.WinForms, Version=18.1.340.0, Culture=neutral, PublicKeyToken=c27e062d3c1a4763 (CLR v4.0.30319) ...
09/12/2018 08:34:03.571 [7132]: 2>    Compiling assembly ActiproSoftware.Shared.WinForms, Version=18.1.340.0, Culture=neutral, PublicKeyToken=c27e062d3c1a4763 (CLR v4.0.30319) ...
09/12/2018 08:34:04.164 [7132]: 1>IMAGE_DIRECTORY_ENTRY_DEBUG size (136) should be a multiple of 28
09/12/2018 08:34:04.664 [7132]: 2>IMAGE_DIRECTORY_ENTRY_DEBUG size (130) should be a multiple of 28
09/12/2018 08:34:04.727 [7132]: 1>    Compiling assembly RoyalDocument.Desktop, Version=1.0.6818.21410, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:04.977 [7132]: 2>    Compiling assembly RoyalUtils.Desktop, Version=1.0.6818.21409, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:06.431 [7132]: 2>    Compiling assembly DevExpress.XtraVerticalGrid.v18.1, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a (CLR v4.0.30319) ...
09/12/2018 08:34:06.461 [7132]: 1>    Compiling assembly RoyalLogging.Desktop, Version=1.0.6818.21453, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:07.134 [7132]: 1>    Compiling assembly Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed (CLR v4.0.30319) ...
09/12/2018 08:34:10.493 [7132]: 1>    Compiling assembly RoyalCommon.Server.RoyalServer.Desktop, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:10.633 [7132]: 2>    Compiling assembly EO.Base, Version=18.2.74.0, Culture=neutral, PublicKeyToken=e92353a6bf73fffc (CLR v4.0.30319) ...
09/12/2018 08:34:12.571 [7132]: 1>    Compiling assembly RoyalPasswords.BrowserExtensions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:13.759 [7132]: 1>    Compiling assembly Fleck, Version=0.14.0.59, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:14.587 [7132]: 1>    Compiling assembly CsQuery, Version=1.3.3.249, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:15.852 [7132]: 2>    Compiling assembly EO.WebBrowser, Version=18.2.74.0, Culture=neutral, PublicKeyToken=e92353a6bf73fffc (CLR v4.0.30319) ...
09/12/2018 08:34:17.149 [7132]: 1>    Compiling assembly EO.WebEngine, Version=18.2.74.0, Culture=neutral, PublicKeyToken=e92353a6bf73fffc (CLR v4.0.30319) ...
09/12/2018 08:34:17.727 [7132]: 2>    Compiling assembly RoyalServer.ManagementEndpoint.Desktop, Version=2.1.20410.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:18.743 [7132]: 2>    Compiling assembly RoyalServer.ManagementEndpoint.Modules, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:18.790 [7132]: 1>    Compiling assembly RoyalDocument.SecurityInterface.Desktop, Version=1.0.6818.21411, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:19.493 [7132]: 2>    Compiling assembly RoyalLastPass.Desktop, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:19.681 [7132]: 1>    Compiling assembly LastPass, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:20.915 [7132]: 1>    Compiling assembly zxcvbn-core, Version=2.1.44.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:21.164 [7132]: 2>    Compiling assembly EasyHook, Version=2.7.6789.0, Culture=neutral, PublicKeyToken=4b580fca19d0b0c5 (CLR v4.0.30319) ...
09/12/2018 08:34:21.820 [7132]: 2>    Compiling assembly RoyalJSON, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:21.883 [7132]: 1>    Compiling assembly RoyalJSON.Document, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:22.102 [7132]: 2>    Compiling assembly RoyalCommon.KeePass, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:22.368 [7132]: 1>    Compiling assembly DevExpress.XtraCharts.v18.1.Wizard, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a (CLR v4.0.30319) ...
09/12/2018 08:34:22.993 [7132]: 2>    Compiling assembly Interop.SHDocVw, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:23.086 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x200018a - DevExpress.XtraCharts.Designer.Native.DesignerModelCollectionEditor.
09/12/2018 08:34:23.149 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x20001d9 - ChartPickManager.
09/12/2018 08:34:23.211 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x20001dc - ChartDataSourceTreeView.
09/12/2018 08:34:23.680 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x2000488 - DevExpress.XtraCharts.Design.KeyCollectionEditor.
09/12/2018 08:34:23.805 [7132]: 2>    Compiling assembly LumenWorks.Framework.IO, Version=3.8.0.0, Culture=neutral, PublicKeyToken=5ad3ea2f85776344 (CLR v4.0.30319) ...
09/12/2018 08:34:23.930 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x100003f - DevExpress.Utils.UI.CollectionEditor.
09/12/2018 08:34:24.039 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000043 - DevExpress.XtraReports.Native.TreeListPickManager.
09/12/2018 08:34:24.149 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000046 - DevExpress.XtraReports.Design.DesignTreeListBindingPicker.
09/12/2018 08:34:25.289 [7132]: 2>    Compiling assembly RemoteCore.Common, Version=3.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:25.383 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000332 - DevExpress.Utils.FormatStrings.CategoryItem.
09/12/2018 08:34:25.446 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000352 - DevExpress.Utils.UI.CollectionEditorFormBase.
09/12/2018 08:34:25.648 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000474 - DevExpress.XtraReports.Native.ResLoaderBase.
09/12/2018 08:34:25.727 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1000477 - DevExpress.XtraReports.Native.DataMemberListNodeBase.
09/12/2018 08:34:25.821 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x10004ba - DevExpress.XtraReports.Native.DataMemberListNode.
09/12/2018 08:34:25.883 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x10004bb - DevExpress.XtraReports.Native.DataSourceNativeTreeList.
09/12/2018 08:34:25.899 [7132]: 2>    Compiling assembly RemoteCore.Viewer.Common, Version=3.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:25.930 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x100054b - DevExpress.Utils.FormatStrings.XmlDataLoader.
09/12/2018 08:34:26.023 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0x1b000127 - .
09/12/2018 08:34:26.195 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0006a9 - DevExpress.XtraReports.Native.ResLoaderBase.LoadColoredCursor.
09/12/2018 08:34:26.320 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0006af - DevExpress.XtraReports.Native.DataMemberListNodeBase.get_DataSource.
09/12/2018 08:34:26.414 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0006b0 - DevExpress.XtraReports.Native.DataMemberListNodeBase.get_DataMember.
09/12/2018 08:34:26.462 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000750 - DevExpress.Utils.UI.CollectionEditor.EditValue.
09/12/2018 08:34:26.540 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000752 - DevExpress.Utils.UI.CollectionEditor..ctor.
09/12/2018 08:34:26.633 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007db - DevExpress.XtraReports.Native.DataMemberListNodeBase.get_IsEmpty.
09/12/2018 08:34:26.664 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007dc - DevExpress.XtraReports.Native.DataMemberListNodeBase.get_IsList.
09/12/2018 08:34:26.742 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007dd - DevExpress.XtraReports.Native.DataSourceNativeTreeList.get_PickManager.
09/12/2018 08:34:26.821 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007de - DevExpress.XtraReports.Native.TreeListPickManager.set_ServiceProvider.
09/12/2018 08:34:26.868 [7132]: 2>    Compiling assembly RoyalDocument.SecurityInterfaceLegacy.Desktop, Version=1.0.6818.21412, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:26.899 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007e1 - DevExpress.XtraReports.Native.DataSourceNativeTreeList.set_ShowParametersNode.
09/12/2018 08:34:27.040 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007eb - DevExpress.XtraReports.Native.DataSourceNativeTreeList.Start.
09/12/2018 08:34:27.227 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007ec - DevExpress.XtraReports.Native.DataSourceNativeTreeList.Stop.
09/12/2018 08:34:27.368 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007ed - DevExpress.XtraReports.Native.DataSourceNativeTreeList.SelectDataMemberNode.
09/12/2018 08:34:27.446 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007ee - DevExpress.XtraReports.Native.DataSourceNativeTreeList.SelectNoneNode.
09/12/2018 08:34:27.540 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007ef - DevExpress.XtraReports.Native.DataSourceNativeTreeList.get_DataMemberNode.
09/12/2018 08:34:27.570 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007f0 - DevExpress.XtraReports.Native.TreeListPickManager.GetDataContextService.
09/12/2018 08:34:27.711 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007f1 - DevExpress.XtraReports.Native.TreeListPickManager.GetTypeSpecificsService.
09/12/2018 08:34:27.852 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007f3 - DevExpress.XtraReports.Native.TreeListPickManager..ctor.
09/12/2018 08:34:27.898 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa0007fe - DevExpress.XtraReports.Design.DesignTreeListBindingPicker..ctor.
09/12/2018 08:34:27.930 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000806 - DevExpress.XtraReports.Design.DesignTreeListBindingPicker.OnNodeExpand.
09/12/2018 08:34:27.993 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e44 - DevExpress.Utils.FormatStrings.XmlDataLoader..ctor.
09/12/2018 08:34:27.993 [7132]: 2>    Compiling assembly Microsoft.AppCenter.Analytics, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:28.008 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e45 - DevExpress.Utils.FormatStrings.XmlDataLoader.CreateCategoryItems.
09/12/2018 08:34:28.040 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e46 - DevExpress.Utils.FormatStrings.CategoryItem.get_Type.
09/12/2018 08:34:28.102 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e4c - DevExpress.Utils.FormatStrings.CategoryItem.SetFormatStrings.
09/12/2018 08:34:28.180 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e4e - DevExpress.Utils.FormatStrings.CategoryItem.GetDisplayName.
09/12/2018 08:34:28.227 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000e5b - DevExpress.Utils.FormatStrings.CategoryItem.get_FormatStrings.
09/12/2018 08:34:28.227 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000ee3 - DevExpress.Utils.UI.CollectionEditor.GetObjectsFromInstance.
09/12/2018 08:34:28.227 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. while resolving 0xa000ee4 - DevExpress.Utils.UI.CollectionEditor.CreateCollectionForm.
09/12/2018 08:34:28.337 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerControl`1.ProcessDialogKey
09/12/2018 08:34:28.352 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerEditor`1.GetEditStyle
09/12/2018 08:34:28.352 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerEditor`1..ctor
09/12/2018 08:34:28.461 [7132]: 2>    Compiling assembly Microsoft.AppCenter, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:29.930 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified.. If this assembly is found during runtime of an application, then the native image currently being generated will not be used.
09/12/2018 08:34:30.102 [7132]: 1>Warning: System.IO.FileNotFoundException: Could not load file or assembly 'DevExpress.Utils.v18.1.UI, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified. (Exception from HRESULT: 0x80070002). If this assembly is found during runtime of an application, then the native image currently being generated will not be used.
09/12/2018 08:34:30.180 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1.PaintValue
09/12/2018 08:34:30.227 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1..ctor
09/12/2018 08:34:30.305 [7132]: 2>    Compiling assembly SQLite-net, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:31.508 [7132]: 2>    Compiling assembly SQLitePCLRaw.core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=1488e028ca7ab535 (CLR v4.0.30319) ...
09/12/2018 08:34:32.368 [7132]: 2>    Compiling assembly System.Linq.Expressions, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:33.024 [7132]: 2>    Compiling assembly System.Linq, Version=4.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:33.727 [7132]: 2>    Compiling assembly SQLitePCLRaw.batteries_v2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=8226ea5df37bcae9 (CLR v4.0.30319) ...
09/12/2018 08:34:34.477 [7132]: 2>    Compiling assembly SQLitePCLRaw.provider.e_sqlite3, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9c301db686d0bd12 (CLR v4.0.30319) ...
09/12/2018 08:34:35.211 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1..ctor
09/12/2018 08:34:35.211 [7132]: 2>    Compiling assembly System.Reflection.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (CLR v4.0.30319) ...
09/12/2018 08:34:35.227 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1.PaintValue
09/12/2018 08:34:35.243 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1..ctor
09/12/2018 08:34:35.243 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1.PaintValue
09/12/2018 08:34:35.273 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerControl`1.ProcessDialogKey
09/12/2018 08:34:35.320 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1..ctor
09/12/2018 08:34:35.320 [7132]: 1>Cannot embed generic MethodDesc while compiling method GradientModeEditorBase`1.PaintValue
09/12/2018 08:34:35.352 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerEditor`1..ctor
09/12/2018 08:34:35.352 [7132]: 1>Cannot embed generic MethodDesc while compiling method GenericTypePickerEditor`1.GetEditStyle
09/12/2018 08:34:35.399 [7132]: 2>    Compiling assembly RoyalServer.ManagementEndpoint.Module.Helper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:36.258 [7132]: 2>    Compiling assembly RoyalServer.Server.Shared, Version=3.0.10726.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:36.852 [7132]: 1>    Compiling assembly System.Web.Http.SelfHost, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (CLR v4.0.30319) ...
09/12/2018 08:34:36.883 [7132]: 2>Warning: System.TypeLoadException: Could not load type 'CryptoObfuscatorHelper.ObfuscationAttribute' from assembly 'RoyalUtils.Desktop, Version=1.0.6818.21409, Culture=neutral, PublicKeyToken=null'. while resolving 0x10000e6 - CryptoObfuscatorHelper.ObfuscationAttribute.
09/12/2018 08:34:36.945 [7132]: 2>Warning: System.TypeLoadException: Could not load type 'CryptoObfuscatorHelper.ObfuscationAttribute' from assembly 'RoyalUtils.Desktop, Version=1.0.6818.21409, Culture=neutral, PublicKeyToken=null'. while resolving 0xa00003c - CryptoObfuscatorHelper.ObfuscationAttribute..ctor.
09/12/2018 08:34:38.148 [7132]: 1>    Compiling assembly System.Web.Http, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (CLR v4.0.30319) ...
09/12/2018 08:34:38.164 [7132]: 2>    Compiling assembly System.Net.Http.Formatting, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (CLR v4.0.30319) ...
09/12/2018 08:34:38.508 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeFormatter.SetDefaultContentHeaders
09/12/2018 08:34:38.773 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_ApplicationOctetStreamMediaType
09/12/2018 08:34:38.852 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_ApplicationXmlMediaType
09/12/2018 08:34:38.993 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_ApplicationJsonMediaType
09/12/2018 08:34:39.071 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_TextXmlMediaType
09/12/2018 08:34:39.164 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_TextJsonMediaType
09/12/2018 08:34:39.211 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_ApplicationFormUrlEncodedMediaType
09/12/2018 08:34:39.227 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeConstants.get_ApplicationBsonMediaType
09/12/2018 08:34:39.242 [7132]: 2>Method System.Net.Http.CloneableExtensions.Clone: type argument 'System.Net.Http.Headers.MediaTypeHeaderValue' violates the constraint of type parameter 'T'. while compiling method MediaTypeFormatterMatch..ctor
09/12/2018 08:34:39.602 [7132]: 1>    Compiling assembly TwoFactorAuth.Net, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:39.648 [7132]: 2>    Compiling assembly Rebex.Castle, Version=1.0.0.0, Culture=neutral, PublicKeyToken=1c4638788972655d (CLR v4.0.30319) ...
09/12/2018 08:34:39.867 [7132]: 1>    Compiling assembly BouncyCastle.Crypto, Version=1.8.2.0, Culture=neutral, PublicKeyToken=0e99375e54769942 (CLR v4.0.30319) ...
09/12/2018 08:34:40.571 [7132]: 2>    Compiling assembly Rebex.Curve25519, Version=1.0.0.0, Culture=neutral, PublicKeyToken=1c4638788972655d (CLR v4.0.30319) ...
09/12/2018 08:34:41.461 [7132]: 2>    Compiling assembly Rebex.Ed25519, Version=1.0.0.0, Culture=neutral, PublicKeyToken=1c4638788972655d (CLR v4.0.30319) ...
09/12/2018 08:34:42.336 [7132]: 2>    Compiling assembly RoyalTS.Importers, Version=1.0.6818.21454, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:43.601 [7132]: 2>    Compiling assembly RoyalUtils.CSVParser.Desktop, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:43.992 [7132]: 1>    Compiling assembly CsvHelper, Version=2.0.0.0, Culture=neutral, PublicKeyToken=8c4959082be5c823 (CLR v4.0.30319) ...
09/12/2018 08:34:44.367 [7132]: 2>    Compiling assembly RemoteCore.Viewer.Core, Version=3.0.6.0, Culture=neutral, PublicKeyToken=null (CLR v4.0.30319) ...
09/12/2018 08:34:44.821 [7132]: ngen returning 0x00000000
09/12/2018 08:34:44.915 [6508]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe update /queue
09/12/2018 08:34:45.009 [6508]: ngen returning 0x00000000
09/12/2018 08:35:12.855 [2156]: Command line: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\ngen.exe install C:\Program Files (x86)\Royal TS V5\RoyalTS.exe
09/12/2018 08:35:13.636 [2156]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.Printing.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:35:13.667 [2156]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.RichEdit.v18.1.Core, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:35:13.745 [2156]: Failed to load dependency DevExpress.Pdf.v18.1.Core of assembly DevExpress.XtraRichEdit.v18.1, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:35:13.792 [2156]: Failed to load dependency DevExpress.Utils.v18.1.UI of assembly DevExpress.XtraCharts.v18.1.Wizard, Version=18.1.5.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a because of the following error : The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
09/12/2018 08:35:14.214 [2156]: All compilation targets are up to date.
09/12/2018 08:35:14.261 [2156]: ngen returning 0x00000000
you can just ignore these errors, they are kind of “expected”. Couple of files are being removed during the build process as we don’t require them within our application (to save same space). But as they are still referenced within some libraries, the ngen does throw out some “file does not exist” errors.
Patrik
ok Thought so, Thank You.
