Use consistent xml element order on save to make version control easier
I’ve struggled to version control a RoyalTS config file because the xml elements change order randomly. This makes it very difficult to see the actual change when using a tool like git and sharing the config with others.
My idea is to simply order the xml elements under each root note
by name ascending. This way a lot of the configuration wouldn’t change in the
way it currently does. It should be a case of running an OrderBy() as part of
the save.
For example, under a connection element:
<RoyalRDSConnection>
  <ID>b3fa4e7c-436b-4925-bf35-08234e03c485</ID>
  <Name>Server1</Name>
  <Modified>06/29/2023 23:14:19.798</Modified>
  <Created>06/29/2023 23:14:19.798</Created>
  <ModifiedBy>James</ModifiedBy>
  <CreatedBy>James</CreatedBy>
  <PositionNr>2</PositionNr>
  <IsConnectionTemplate>False</IsConnectionTemplate>
  <AutomaticallyCalculateScaleFactor>True</AutomaticallyCalculateScaleFactor>
  <ColorDepth>24</ColorDepth>
  <ColorFromParent>False</ColorFromParent>
  <ConnectToAdministerOrConsole>False</ConnectToAdministerOrConsole>
  <CredentialFromParent>True</CredentialFromParent>
  <CredentialId>00000000-0000-0000-0000-000000000000</CredentialId>
  <CredentialOmitDomain>False</CredentialOmitDomain>
  <CustomImageList>{}</CustomImageList>
  <DesktopHeight>0</DesktopHeight>
  <DesktopWidth>0</DesktopWidth>
  <Favorite>False</Favorite>
  <LocalZoom>False</LocalZoom>
   <ParentID>b276350b-ff70-407c-adb8-a15fe74effe4</ParentID>
  <RDPPort>3389</RDPPort>
  <ScaleFactor>100</ScaleFactor>
  <SmartReconnect>False</SmartReconnect>
  <SmartSizing>False</SmartSizing>
  <URI>Server1.local</URI>
  <UseGlobalPlugInWin>True</UseGlobalPlugInWin>
</RoyalRDSConnection>
Order the child elements by their element name:
This doesn’t break the schema, but keeps things more consistent
between saves.
Thanks and keep up the good work on this excellent tool
James
