Use Bash to pre-configure Royal Application
Much like this powershell version: https://www.royalapps.com/blog/use-a-powershell-logon-script-to-pre-configure-royal-ts-settings
It would be great for MacOS users to be able to preconfigure the application before launch for a better end user experience.
Hi Ralph,
that is already possible! I believe you will find all the information that you need here:
https://www.royalapps.com/go/kb-ts-mac-preferences
​Please note that as of Royal TSX 4.1.2 you can place your license file in the system folder /Library/Application Support/Royal TSX to make the license available to all users on the machine.
Kind regards,
Germar
