I’m new to RoyalTS… I imported a bunch of terminal/SSH connections from a different connection management tool. That tool used putty for SSH connections. I had made some specific modifications to putty, that made it easier for me to use… among other things, i set a white background with black text.
In RoyalTS, i’ve updated my default terminal connection settings, but there doesn’t seem to be a way to apply those settings to all of my existing terminal connections.
Is there an easy way to apply these changes to all of my existing SSH connectors?
(there are a LOT of connectors, doing it by hand would be a worst case scenario)
Thanks in advance
