I have been using Royal TSX 4.2.1 on Mac OS 10.13.6 for a while now to connect to servers at work using smart card. It connects fine to few of my Windows 2008 and 2012 Servers and never get the popup for “Select or Specify Credentials” - having to deal with credentials directly on the windows servers - just select the user on the server and put in my passcode. I got new Windows 2016 servers and no matter what i do i get the prompt of “Select or Specify Credentials” even before it establishes connection and i don’t know what to use there.
I tried creating new connection using the same settings that i had for my working connections. I even tried duplicating the existing working connection. when that didn’t work, i even tried using the existing connection just by changing the computer name. I keep getting this “Select or Specify Credentials” and I don’t know what to use. Any help will be greatly appreciated.
