Unable to connect concurrently to multiple hosts behind the same RDP gateway
Greetings, when I try to connect concurrently to multiple hosts behind the same RDP gateway, the second session closes immediately, and the first reconnects. To connect to the second session, I must close the first.
I’ve tried both RDP plug-ins and the outcome is the same.
I don’t have this problem with MSTSC.EXE.
This is with 7.0.20327 - Beta on Windows.
Is this a known issue? Can I help with troubleshooting?
Hi Timothy,
May I ask if this problem occurred in the previous beta and if it also occurs when using our latest stable build 6.1.60329?
If possible, could you create a new support ticket here and send us the logs by following these steps:
  • Go to Royal TS Options –> Logging
  • Set “Logging Level” to “Debug”
  • Enable “Save to File” to any path you want to
  • Try reproducing your issue
  • Disable “Save to File” option
  • Attach the log file to the ticket
Thanks & best regards,
