Hi everybody, I’m evaluating TSX connecting to my ssh appliances. Often I start a tail -f into application logs.
Is there a way to send CTRL-BREAK via command o task to interrupt the tail?
Thank You,
Regards.
Fabio.
Thank You,
Regards.
Fabio.
Hi Christoph,
thanks for your feedback. Following your suggestion I’ve achieved the goal with CTRL-C and the following key sequence:
{HOLD:CTRL}C{RELEASE:CTRL}
Thanks again.
Fabio.
Hi Fabio,
thanks for the follow-up and glad your key sequence worked for you.
If you need anything else, let us know, otherwise have a nice day!
