Trap/Capture mouse to client region
Forgive me if this is already an option, I started using RoyalTS about 15 minutes ago and cannot find such a feature…
I’d like to trap the mouse into the remote client region. I’m frequently darting around to the four corners of the screen, and would like the mouse to remain trapped in the remote session and only allow me to escape it while I’m pressing a certain key like CTRL as I’m approaching the bounds of the remote session screen.
Hi Mike,
this is currently not implemented and I’m not sure if it can be implemented. We are using the Microsoft RDP ActiveX control which ships with Windows and depending on some settings (like Windows key redirection), Royal TS may not be able to recognize the keystroke when the session has the input focus. So, it would then be impossible to escape the trap.
