TeamViewer Login
When connecting to TeamViewer I need to send Ctrl+Alt+Delete to be able to paste username and password.
How do I send Ctrl+Alt+Delete?
This is personal login so I can use Key sequency without any issues.
Hi Reine,
when you use the TeamViewer connection, Royal TS is basically just starting the Team Viewer process through the command line. There’s no deeper integration possible at the moment. This means, that we can’t really interact with the session/window the same way as with other connection types. I’m afraid, you can only send these kind of keyboard combinations using Team Viewer itself.
