System Requirements for Royal TS (for Windows)
Royal TS V7
Since V7 is a self-contained .NET 10 application (framework ships with the product), the system requirements are basically the same as .NET 10, which can be found here:
https://learn.microsoft.com/en-us/dotnet/core/install/windows#supported-versions
Also, starting with Royal TS V6 we dropped official 32-bit (x86) support but gained native ARM64 support for Windows 11 on ARM64.
While we do test Royal TS for Windows on Windows 10 Client (22H2) and Windows Server 2016/2019, it’s very likely Royal TS will also run on Windows 7 SP1+ and Windows 8.1. Additional requirements like MS Visual C++ runtimes may apply (see link above).
Compatibility with Royal Server
In general, we only support the current version of Royal TS running with the current version of Royal Server.
For Royal TS V7 for Windows, the supported version of Royal Server is V5.
We do not recommend using older versions of Royal Server. They may work but cannot be guaranteed.
We support these older combinations only on a best effort basis.
Royal TS V5 and earlier
Required Software
  • .NET Framework 4.7 for Royal TS V4.2 and later
    Download the offline installer
    Note:
    .NET Framework 4.7 is supported on Windows 7 SP1, Windows 8.1, Windows Server 2008R2 SP1, Windows Server 2012, Windows Server 2012R2, Windows Server 2016 and Windows 10 Anniversary Update (Build 1607 and later).
    Windows 10 (Build 1511) does NOT support .NET Framework 4.7. If you are running a Windows 10 build lower than 1607, please keep on using Royal TS 4.1.x which can be downloaded from here.
  • .NET Framework 4.6.1 for Royal TS V4.0.x and V4.1.x
  • Since V3.2 Royal TS requires the Visual C++ runtime libraries to run the internal TightVNC viewer. The installer will automatically download and install those packages for you. In case you are using the Royal TS zip file, you can download and install those files manually:
    Download the VC++ 2015 Runtime here:
    https://www.microsoft.com/en-us/download/details.aspx?id=53840
  • To use the PowerShell Module in Royal TS, PowerShell V4 or later is required.
Operating System Requirements
Operating System 64 bit 32 bit
Windows 11 * :check_mark:
Windows 10 * :check_mark: :check_mark:
Windows 8.1 :check_mark: :check_mark:
Windows 8 :check_mark: :check_mark:
Windows 7 SP1 :check_mark: :check_mark:
Windows Vista SP2 :check_mark: :check_mark:
Windows Server 2022 :check_mark:
Windows Server 2019 :check_mark:
Windows Server 2016 :check_mark:
Windows Server 2012 R2 :check_mark:
Windows Server 2012 :check_mark:
Windows Server 2008 R2 SP1 :check_mark:
Windows Server 2008 SP2 :check_mark: :check_mark:
  • Please check the Note above under .NET Framework 4.7 for Royal TS 4.2 or later.
    More information about the .NET Framework and Operating System support can be found here.
