I would like to have the possibility to copy files via RDP connections from Host to Client and from Client to Client
The goal is to Cmd-C on my MacOS, then Ctrl-P in the remote RDP session and have the file in question transferred
Also, Ctrl-C in one RDP session and then Ctrl-P in another RDP session would be a great addition
Hi Steven,
as much as I would like to implement this feature, it’s unfortunately not supported by FreeRDP on the Mac at the moment.
As soon as it’s implemented in FreeRDP, we will immediately make sure you can use it in Royal TSX as well.
Is there any other alternative to freerdp in a mac (like using the MS remote desktop for mac) that would enable this feature?
Unfortunately that’s not possible.
You can however use the drive redirection feature which lets you transfer files as well.
Hi Felix,
Is there any contact/group we could reach out to from FreeRDP to request this feature is ported from the Windows FreeRDP library to the MacOS version of it?
You can file feature requests on the FreeRDP Github page: https://github.com/FreeRDP/FreeRDP/issues
Hi Felix,
Seems xfreerdp is able to do Client to Host?
https://github.com/FreeRDP/FreeRDP/issues/5688
Is it possible for Royal TSX to use this library?
Hi Steven,
xfreerdp is based on X11 which is mostly used on Linux. Unfortunately the same APIs are not implemented for macOS so that’s why we currently can’t support this feature in Royal TSX.
regards,
I’ve come to this app from the Devloutions one which I thought also used FreeRDP. It can copy/paste files in RDP. This is also a feature I’d really like to see in Royal.
Hi Clayton,
as far as I’m aware Remote Desktop Manager for Mac doesn’t have this feature.
They do however have drive redirection, just like Royal TSX. Go to the “Redirection” settings of your RDP connection and select a folder to redirect under “Disk drives” to enable it.
Apologies, you are right… I mostly use RDM on Windows. RDM on Mac has been very problematic for me, hence switching to Royal… hopefully freerdp implements this feature!
Hi Clayton,
I just wanted to follow up and let you know that we have implemented clipboard copy & pasting of files via RDP. Currently, this feature is only available in the latest beta version which can be downloaded from here:
https://www.royalapps.com/go/kb-ts-mac-downloadbeta
Any and all feedback is greatly appreciated. Thanks!
Kind regards,
Germar Tischler
Great worked for me… thanks for the update and release.
