Suggested features
In “Microsoft Remote Desktop” app have "Use Mac Shortcuts for copy,cut,paste and select all,undo,and find"options in the future,I hope that royal tsx will update similar function options in the future。
Hi Jason,
please open the properties of your RDP connection, navigate to the “Input” section and enable both “Windows Keys Passthrough” and “Remap macOS keyboard shortcuts to their Windows equivalent”.
That should do the trick!
Thanks, I will try do it!
