Sort passwords
In royal ts when you click on a password it is possible to see its security level is high or not. Weak, … Unfortunately it is impossible to sort them in security order to highlight the called “weak” or “fair”.
Would it therefore be possible to set up a function to bold or sort these less secure passwords?
Thanks in advance,
Check out the latest beta here:
It has a new feature called “Password Analyzer” (on the Data ribbon tab).
