Is it possible to bind a keyboard shortcut to a Key Sequence Task?
Thank you
Thank you
Right now this is not possible but we are working on that feature for V6. Unfortunately we don’t have a release date yet.
Thank you.
The key sequence is a great feature but it is not very convenient using the mouse every time I need to trigger it.
I look forward to the V6.
Meantime, just wondering if there is another way to issue CLI password using a keyboard shortcut? I access a lot of devices via Jumpbox so I need to issue the same password multiple times in a single SSH session.
Not within Royal TS as I mentioned before. I guess you could make use of other apps which are specialized in that area, like AutoHotKey.
Thank you!
Hello, any update regarding this feature request ?
