Shared document and connection via gateway
I have an instance of royalTS in location A and an instance in location B
both instances use the same shared document.
RoyalTS in location A need to connect to all devices via a royal server gateway. RoyalTS on location B does not and cannot.
What is the way to configure the shared connection so A will connect through gateway and B will not?
the best approach is to use “Overrides”:
https://www.royalapplications.com/go/blog-ts-winmac-overrides
Perfect. Noticed you can also right click on the connection and select connect with options and then use gateway.
Sure, that would work as well.
