SFTP Overwrite
Hi guys.
Example:
I should upload a folder called “NumerOne”.
The folder “NumberOne” already exists in destination and their contents too.
The problem is that I must click “Yes” for every folder/file to overwrite it. If I have +1000 files… You will understand.
There is a way to do an “overwrite all” or something?
Anybody?
the file transfer plugin included with the first public beta of Royal TSX V4 supports this now.
The feature has been implemented in V5 and is ready to download:
https://www.royalapplications.com/ts/win/download
