Set start path for SFTP on my machine
Hi, is there a possibilty to set a default path on my machine when using sFTP via the menu on an existing SSH connection?
Thank you
You can tweak the file transfer default settings in the “Application” document to change the default path. Alternatively, you could create one or more templates for file transfer which can be executed in the context of your SSH connection with specific settings. See also: https://docs.royalapps.com/r2021/royalts/tutorials/working-with-templates.html
Thanks, found it! :slight_smile:
You’re welcome!
