Set fixed width for navigation tree panel
When RTS is open on a PC and you later RDP to that PC from another computer, the navigation tree panel gets clobbered/resized. Example process that can cause this:
Step 1. On Computer A, I’m using RoyalTS to RDP into Servers
1, 2, and 3. I have the navigation tree panel spacing just how I like it and
everything is working great. I lock the PC with everything running.
Step 2. Later on, from Computer B, I RDP into Computer A –
either using RTS or native RDP Client. RTS is still running and still connected
to Servers 1, 2, and 3, but the navigation panel spacing has become contorted.
I fix it and everything is great.
Step 3. Later still, I return to Computer A, and unlock it.
Again, RTS is still running and connected to the 3 servers, but once again the
Of note, Computers A and B may be running different
resolutions/scaling/monitor configurations.
I don’t think this is necessarily a bug - when DWM is recompositing after the resolution/monitor/login changes it can cause weirdness. So, what I’m requesting is a feature that allows RTS to avoid being clobbered by DWM.
I’d like to add to this request. I’ve noticed the same issue and only use RoyalTS on the same PC. Previous versions of RoyalTS would remember the width when I opened the application but now every time I open the application I have to resize it. This stoped working sometime in v6 and the issue persists in v7.
I would also like a feature to lock the width of the navigation panel.
moving fast, I’ll occasionally drag it by accident.
