Hey folks,
I’ve got a bit of a pickle I’ve been trying to solve. I have been hosting a Windows bastion running Royal TS which I’ve remoted into and then used to RDP into other Windows hosts. My company requires that all bastions have 2 factor login using Duo.
I saw Secure Gateway recently and spun up a linux host and installed the Duo 2f on it. When you login it asks you the following:
Duo two-factor login for user
Enter a passcode or select one of the following options:
1. Duo Push to XXX-XXX-XXXX
2. Phone call to XXX-XXX-XXXX
3. SMS passcodes to XXX-XXX-XXXX
Is it possible to handle this as part of the Secure Gateway login? Like maybe show the prompt in the remote session window then wait for the user’s response? At the moment I’m getting the error attached.
