We would need to define several Secure Gateway Server in parallel so the Gateway Server is not a single point of failure. In case one Gateway Server is down a second (Backup) Gateway Server should be able to handle the request transparently or maybe after a reconnect.
Currently it’s not possible to define more than one Secure Gateway Server.
Thanks for the feedback. While we currently don’t have this feature on board right now, I want to mention that you should be able to use a standard load balancer to make a secure gateway failover to another one. You can follow this guide to install a second Royal Server with the same configuration as the first one:
Since version Royal TS V6 it is possible to specify multiple computer names separated by semicolons in the Secure Gateway properties.
Hans
