Does Secure Gateway support auth using Private Key ?
If not have any plan to do that ?
Hi Marcos,
yes, Secure Gateway has always supported private key files. Just make sure that you specify your username and private key file but leave the password field empty.
you must specify an existing credential with a private key set up. It’s not possible to specify a private key at the moment when using “Specify username and password” credential mode.
