Rustdesk in Royal TS
Hi, was wondering if RustDesk might be supported in the future. If you don’t know Rustdesk yet, it’s an alternative to Teamviewer and Anydesk that is 100% Open source and mostly written in Rust. Would be cool if Royal TS has support for it.
Hi Tom,
there are currently no plans to integrate Rustdesk directly into Royal TS. Royal TS is a .net application and as far as I know there’s no wrapper available. You could try to integrate the client using the External Application connection type.
Any change in these plans?
Hi Raphael,
from what I know, there’s still no SDK to consume and integrate RustDesk in other applications. The best bet is using external app connection type to integrate it with Royal TS.
Thx, i didnt know that existed
+1 for establishing a direct collab with Rustdesk.
