RoyalTSX MAC - Nested Secure Gateways and SOCKS proxy for Web
Secure Gateways shall:
  • have an option to be nested so that I can define gateway B behind Gateway A
  • option to specify which ports to forward
  • use sessions defined in .ssh/config (currently I have a gateway B behind Gateway A and need to reach machines behind Gateway B - Gateway B has a reverse tunnel to Gatway B - currently I just create Terminal and call session defined in .ssh/config so RoyalTSX just organizes windows and creates session tree rather than use its own config)
WebKit doesn’t support SOCKS proxy as far as I was reading on a forum - but maybe there is a way to spawn a new terminal just for a specific web session with a SOCKS gateway set “globally” (as env?) in this specific session.
Using lates 3.3.2
we just released a Royal TS V6 for Windows beta release where you can test this feature (Royal TSX will soon follow):
https://www.royalapps.com/blog/dependent-gateways
Hello Michael,
I wanted to inform you that we’ve just released a brand new Royal TSX V26 Beta build, which comes with various improvements as well as with the WebKit SOCKS proxy configuration support.
If you’d like to test the new Royal TSX V26 Beta, you can download it here:
