[RoyalTS v7] Color Palette Overwrite Not Working Globally For Putty Terminal Plugin
I recently upgraded from RoyalTS v6 (portable) to v7 (portable) and I face the issue, that I can’t overwrite my putty terminal color settings anymore.
Steps to reproduce:
  1. Set putty as you default terminal plugin:
View -> Plugins -> Terminal -> Terminal (Based on Putty) -> Set to default
  1. Test a ssh-connection - background should be black:
  2. Change color palette for the plugin:
View -> Plugins -> Terminal -> Terminal (Based on Putty) -> “Press the little dropdown arrow” -> Overwrites -> Colors -> Palette -> Choose e.g. Solarized
  1. Save + Restart RoyalTS
  2. Test a ssh-connection - background is still black
Changing the colors per ssh-connection works:
  1. Right-Click your ssh-connection -> Properties -> Colors -> Palette -> Choose e.g. Solarized
  2. Test a ssh-connection - background is orange
Is there another global setting to change the colors in the RoyalTS v7 putty plugin which I did not see? Or is this a bug?
Best regards
Gudrun
Hi Gudrun!
By default, overrides are only applied while holing the Alt key while connecting. You can change this behavior here:
https://docs.royalapps.com/r2023/royalts/reference/options.html#apply-overrides
Does this help?
thank you for the hint.
I changed:
View -> Options -> Behaviors -> Modifiers -> Dropdown: “Always apply, except when holding the Alt key”
Now it works perfect :slight_smile:
Gudrun
You’re welcome! Glad I could help.
