Currently RoyalTerminal seems to not copy the selected text directly to the clipboard. You need to manually press CTRL+Ins to really copy the selection.
Most Linux users shouldn’t be too bothered by this as it is a default behavior of many terminal emulators, but Windows users used to PuTTY copying directly after select to clipboard may have some … surprises ![]()
Ghostty offer an option to control this feature (copy-on-select) that can be set to
trueto only copy to the selection clipboard (internal) -
clipboardto copy the selection automaticaly to the system clipboard/selection clipboard, orfalseto do nothing. -
falseto do nothing
Additionnaly, there is another option (right-click-action) that can be useful with copy-on-select for some users as it can change how it react to the right-click
copy(pretty obvious
)copy-or-paste(useful 2-in-1 withcopy-on-paste = false)paste(standard for PuTTY users
)nothing(this one is for those who don’t really use mouses
Default Rebex plugin does not offer much options (other than the “Mouse Paste”) but the PuTTY plugin offer such options already:
Would be a nice addition ![]()
Best Regards,
Nicolas.
