I noticed that ctrl-s is no longer passwd through to a VM when using the FreeRDP plugin. Basically whenever I press ctrl-s it just saves to document in RoyalTS itself …
Is there some setting to control that? Do I need to remove the hotkey for RoyalTS to save the current document?
Thanks & BR,
Martin
