RFE - shortcut to connection in the toolbar
i would need shortcuts to dedicated connections in the toolbar. Basically the session manager is a good tool but when you are maximizing the RDP window usually you hide the session manager as well.
Once this is hidden you have only two ways to reach another connection. Either by using the keyboard shortcut or by using the mouse and let the session manager display once the mouse comes close to the left screen side.
The frist way always resize the RDP window which is pretty annoying. If you use the auto hide function this function is annoying too since every time you come to close to the left screen side it is being displayed.
Thats why shortcuts in the toolbar are a possible solution for this problem.
I’m happy to report that this feature will be included in the next Royal TSX 26 Beta release.
A new “Quick Access” toolbar item will be available when customizing the toolbar. When you add such an item to the toolbar (and you can add as many as you like), you can then drag connections and tasks onto it to create shortcuts to those objects in the toolbar.
Hope that helps! Please let us know if it works as expected once the next beta lands.
Thx,
Felix
