RestrictedAdminMode for Dynamic Folder objects
is it possible to set the RestrictedAdminMode in the json?
I tried with
"RestrictedAdminMode":  "true"
to no avail. Not sure what the correct syntax would be, or if this is even possible.
thank you,
regards
OK, found the relevant doc:
https://docs.royalapps.com/r2021/scripting/rjson/advanced-scenarios.html
Please check out the “Advanced Scenarios” chapter in our docs:
Hello Stefan,
thanks, managed to get it work. Thanks for this really powerful feature.
Schönen Tag noch!
You’re very welcome! Glad I could help.
