Upon doing some testing, it would be great to have a “Reset to Default values” button within the connection default settings configuration.
If a user accidentally changes a value of a connection’s default settings (e.g. port), they might not know the actual default value to reset it to, which might lead to the problem, that some connections won’t work anymore.
