Reset Ribbon does not reset it correctly
In Royal TS (Windows) 7.0.50809.
Click Customize the Ribbon > Reset > Reset All customization.
It will not reset the Ribbon like new install.
Hi Lan,
I will look into it. As a workaround you could just delete the file code4ward.RoyalTS.RibbonSettings-7.xml in %appdata%\code4ward while Royal TS is not running.
