hey,
requesting export of a single folder in right-click to csv.
hey,
Hi nimrod,
thanks for the feedback. The context menu has already many items and we try to keep it as concise as possible. CSV export seems to be a feature which isn’t really used frequently by most users. You can, however, put the Export CSV command from the Data ribbon tab to the quick access toolbar for easier access or assign a keyboard shortcut to it.
https://docs.royalapps.com/r2023/royalts/user-interface/commands.html#-keyboard-shortcuts
