Remove window from application?
With Royal TS one can remove the embedded window of an RDP session and move it around to other screens. This would allow me to view two RDP sessions within the app side-by-side.
With TSX I cannot seem to find that option. My only choices are Main Screen (embedded) or Fullscreen. Is that feature not available?
Hi Will,
I believe this should be possible:
Can you please try to drag & drop the embedded RDP window to unlink it from the Royal TSX view, so an External Window is created?
You’re right, Christoph. For some reason it was not working for me. But after a restart of the application, it began to work as you stated. First step in “Troubleshooting 101” was missed :slight_smile:
Hi Will,
thanks for the follow-up and glad this worked for you.
Have a great day!
