Rebex overide for color error
I am trying to edit the text highlighting for terminal in the Rebex override section and encounter an error that states “Object reference not set to an instance of an object.” I am unable to make changes to any of the color scheme settings after this point. Has anyone else delt with this?
Hi Zach,
sorry that you are experiencing this issue.
I just tried to reproduce the issue using Royal TS V7.3.50701 by adding a Regular Expression in the Rebex Override > Text Highlighting section, however, was not able to replicate the behavior:
Would you perhaps be able to share your reproduction steps, or alternatively, create a new support ticket with the reproduction steps, so we can look into this?
Thanks & best regards,
