Rebex backend: SSH → “Connect using SFTP/SCP” fails when connection uses proxy
When using a proxy in an SSH connection (Rebex backend), the Quick Actions → Connect using SFTP/SCP buttons fail with a timeout.
The base SSH session connects fine through the proxy, but the secondary SFTP/SCP session never reaches the host.
Error shown:
Rebex.Net.SftpException: Connection attempt timed out.
Rebex.Net.ProxySocketException: Connection attempt timed out.
Environment
Royal TS for Windows v7.3.51009
Backend: Rebex
Proxy type: SOCKS5 (internal corporate proxy)
Secure Gateway: not used
Host reachable only through proxy
Same issue in reverse direction (SFTP → “Connect using SSH”)
Additional information
Using the PuTTY backend, SSH↔SFTP/SCP switching through the same SOCKS5 proxy works normally.
Thanks for the bug report! The next release will have this fixed. Stay tuned…
