I have an RDP connection set to connect/open in full screen mode. The connection bar appears and I can minimize/shrink window without issues using the connection bar. "Do not show connection bar’ is not checked.
If I use the ‘embed’ option the window is embedded, but when I switch back to full screen mode the connection bar is missing.
This is happening on a Microsoft Surface Book 2 (3000x2000 resolution, 200% scaling). I get the same results with high DPI scaling ON or OFF.
I’m new to Royal TS, installed yesterday, so I may have a setting issue, but I can’t find an option that controls this. I have restarted Royal TS a few times and the problem is consistent.
