After installation of the last beta (30.9.26) the proxmox module is missing. As I saw, the same problem was in July…
I just tested the latest release and proxmox is working fine for me. Are you using Royal Server beta as well, maybe?
Hi Stefan
No, just the royal ts as beta. I have another problem with the chromium engine and royal secure gateway and wanted to test it with the edge plugin, which is only available in the beta (as christoph m. told me).
So I downloaded the version from yesterday an tried the proxmox module too, but I’ve got an error: Proxmox module is missing.
Looks like you got a stale/expired older copy of the download. Can you try to download again? Copy the link in the URL bar and append some query string to ensure no cached/stale version is downloaded.
I deinstalled royal ts, installed the beta (msi, with the proxmox module folder!) and startet it.
Now it seems to work. Just direct connections.
Connections via Secure Gateway aren’t working. (Same module error)
Do we need a beta version there too?
Yes, if you want to use the plugin via the Royal Server, you need to run the latest beta Royal Server as well.
