Prompt for Passphrase of Private Key using Secure Gateway
I would love to have the option to set a checkbox in an Private Key Object which says “Prompt for Passphrase”. Currently adding an Private Key which has a passphrase set into an Authentication Object and leaving the “passphrase” field empty causes an error when trying to establish a connection over the secure gateway function. (Screenshot)
Using a normal Terminal Connection I get asked in the actual terminal “Plugin”.
I would love the feature for RoyalTS (Windows) and RoyalTSX (MacOS).
The reason I would love this feature is because I try to not store any credentials in the royalTS document because of security guidelines set up from our organisation.
That would be very nice!
