Bonjour,
je viens d’installer l’application Royal TS sur mon pc et j’ai configuré les paramètres de connexion (credential, serveur, etc…).
Lorsque j’ai voulu me connecter sur un de mes serveurs en SSH, j’ai une fenêtre d’erreur suivant ‘Royal TS is not able to connect because an insecure cipher is required by the remote host’.
Si vous pouvez m’aider merci d’avance.
cdlt Aubert
Je vous joins le message d’erreur.
hello,
I installed Royal TS and configured the servers (credential, hostnames servers, terminal, etc…) and when I want to connect on a server under SSH, I have an error message with cipher (see file attached ‘error message’).
My colleague has installed Royal TS and no error message on his laptop (no configuration with cipher).
Thanks a lot for your help.
BR
Aubert
according to the error message, the host name is invalid. Can you post a screenshot of your hostname configuration (watch out for illegal characters like blanks). If you don’t want to post screenshots here, please open a support ticket for further assistance.
Thank you,
The problem has been resolved, this is a problem with the export file thanks a lot for your help.
BR
Aubert
