Prevent disconnect notifications
While I rely on RoyalTS completely there are many times it drives me crazy.
One thing is the disconnect popup notifications. Is there any way to stop these.
The show up in the middle of the screen and if you try to get rid of them they take you out of the screen you are using to the now dead terminal. It is infuriating.
I am sure I am missing a big button that says “stop interrupting my work flow with annoying messages floating on top that will take you out of the current terminal you are working on and bury our sever in a list of live connections” but I cant find it.
you can disable the notifications in the Windows Settings under Notifications & actions.
Alternatively you can disable certain notifications in the Royal TS’ View -> Options -> Notifications section:
https://content.royalapplications.com/Help/RoyalTS/V5/index.html?reference_options_notifications.htm
