In an attempt to provide parity of features between RoyalTS and RoyalTSX, could a persistent key-sequence broadcast box be added to RoyalTSX? The equivalent option in RoyalTSX disappears after every key-sequence executed, requires you respond to a prompt, and has to be reopened after every execution.
In addition to the persistent dialog box, being able to select a subset of connections to broadcast the text to would be nice, the same way RoyalTS allows.
