Is there a way to override the Username on the connection when using the credential from the parent folder? I login to different servers using SSH with the same private key but different username. The credential object has Username blank and the shared private key, but then I have to enter the host’s username when connecting. I haven’t found a way to specify the Username on the connection while also using the credential object inherited from the parent folder.
I’m afraid this is currently not possible. When you choose to use the credentials from the parent folder, it includes username (and password) as well as the private key file configuration. Thinking about the scenario, I’m not sure how we can support this scenario easily based on the current mechanisms at play with credentials. We might have a solution in the future for this though…
